EternalStudent's avatar
EternalStudent
Apprentice
Feb 24, 2022
"WLAN Extensibility Module has failed to start." with A7000 USB wifi adapter
Module Path: C:\WINDOWS\system32\Rtlihvs.dll
Error Code: 126"
Is the error event information I get with every boot (event ID 10000, Task Category None).  Looking online there was a suggestion to delete a registry key.  That the driver maker mistakenly kept a default value, but didn't include the required DLL.  I'd rather the driver maker (Netgear) fix their software than every user delete a possibly useful registry key to silence this error.
As far as I can tell my A7000 is working.  I'm using it in a home network setup, with the Xfinity XB6 combo modem + router.  No "WLAN Extensibility" settings should be coming through that I know of (after reading a little, it sounds like a way for service providers to force something on the client).
Current version of driver is installed.  Windows 10 x64 with latest released patches (not the "preview" version of the next update I'd have to manually get).
  • michaelkenward's avatar
    michaelkenward
    Have you tried uninstalling the drivers?
    Remember to remove the "hidden" USB drivers while you are at it.
    Tell device manager (View) to "Show Hidden Devices"
    Wifi adapters
