Icemankool's avatar
Icemankool
Follower
Apr 29, 2025
WNA 1100 Alternative / upgrade?
I have a Roland VR09 organ. Thought I'd try to connect via WI-FI. Roland specify that the WAN1100 (RL) is used.. trouble is, they're no longer available. Question is, is there an "upgrade" / alternative to this dongle that will work?
Running W11, with Smart Hub 5. although, connection will be through an old IPAD 2 running IOS 9.3.5..
Thanks everyone..
1 Reply
  • plemans's avatar
    These older devices have specific wifi adapters that can be used with them because they require drivers. Your best bet is to check with the roland forums (doubt they'll have anything) to see if something else will work. It doesn't look like it has an ethernet adapter so that's not an option. A different option is to watch the local thrift or ebay for used items. Again, you're pretty limited because of what you're connecting it to.
