Soulres
Jan 23, 2021Aspirant
WNA1100 Can't Load SUPPTools.dll
Trying to newly install a N150 WNA1100 but everytime I try to run ANY of the setups, I get "Unable to load Supptools.dll " that are located in the appdata/temp folder. I am using windows10.
- Jan 29, 2021
This problem outlived the problem it was designated to solve. This was never resolved and I no longer will be watching this.
michaelkenward
Jan 24, 2021Guru - Experienced User
Which version are you trying to install? You don't say.
This is an ancient (2009) adapter designed for earlier versions of Windows. Older installs probably won't work.
WNA1100 Software Version 2.2.0.1 | Answer | NETGEAR Support
Even that is five years old. Maybe Microsoft has done something to break it.
- SoulresJan 25, 2021Aspirant
I have tried all,even tried installing the Original then updating to the newest version (Thats win10 compatable) Not even 4 months ago I used this on another windows10 machine with no issue. Its not the adapter either as The installer is what stops it. (Yes it is not plugged in when attempting.)
- SoulresJan 29, 2021Aspirant
