RAYGUITARWATSON
Dec 11, 2020Follower
WNA1100 PASSWORD
I have just got a 2nd hand one of these to connect a Roland Integra 7 to I-pad - on trying to install, the password is needed by the Roland - is there a way to re-set or look this up or is it necessa...
Dec 11, 2020Guru - Experienced User
Have you checked with roland?
From looking at it, the roland requires a wna1100-RL.
It could be a certain version running modified firmware. I don't think a stock WNA1100 is going to work.
https://www.roland.com/global/products/wna1100-rl/
From looking rolands site, its a plug and play for the integra with the proper firmware. . the password should be for whatever your router/ipad password is to connect to.
