alanrkeen
Dec 21, 2023Aspirant
WNA3100 - N300 Wireless USB Adapter
Does the adapter work with Windows 11
Dec 22, 2023Guru - Experienced User
that adapter was released in 2009. when windows 7 was being released. And it hasn't had much for updates as its eol.
Its also really slow compared to current generation equipment.
One fo the generic windows drivers might work if you already have that USB adapter. Try plugging it in and seeing if anything self installs. You could even try one of the standalone versions from the support site.
but I wouldn't invest to much time or money into getting something that old/slow to work in newer devices.
alanrkeen
Dec 22, 2023Aspirant
Thanks for your answer, I will try and plug it in the machine, as I have two brand new N-300 adapters and do not want to run ethernet cables across the room.
