alanrkeen
Dec 22, 2023Aspirant
WNA3100 - N300 Wireless USB Adapter
Does the adapter work with Windows 11
Hasnainmir
Jan 04, 2024Tutor
The NETGEAR WNA3100 N300 Wireless USB Adapter is generally designed for compatibility with Windows operating systems, including Windows 7, 8, and 10. I don't think it will work
- alanrkeenJan 06, 2024Aspirant
all a money making racket.
upgrade operating system so you must buy new Equipment.
- michaelkenwardJan 06, 2024Guru - Experienced User
No one is forcing you to update your operating system.
Keep the old one and put up with the consequences.
- schumakuJan 07, 2024Guru - Experienced UserReview the release notes of the last released WNA3100 and WNA3100M standalone drivers - the WHQ drivers will be workable with modern Windows 11 systems.
- michaelkenwardJan 07, 2024Guru - Experienced User
schumaku wrote:
Review the release notes of the last released WNA3100 and WNA3100M standalone drivers - the WHQ drivers will be workable with modern Windows 11 systems.Drivers installed, but will not see the USB adapter when plugged in.
Might be something to do with the USB drivers for the motherboard.
