alanrkeen
Dec 21, 2023Aspirant
WNA3100 - N300 Wireless USB Adapter
Does the adapter work with Windows 11
Hasnainmir
Jan 04, 2024Tutor
The NETGEAR WNA3100 N300 Wireless USB Adapter is generally designed for compatibility with Windows operating systems, including Windows 7, 8, and 10. I don't think it will work
alanrkeen
Jan 05, 2024Aspirant
all a money making racket.
upgrade operating system so you must buy new Equipment.
- michaelkenwardJan 06, 2024Guru - Experienced User
No one is forcing you to update your operating system.
Keep the old one and put up with the consequences.
