Niclas_sql
Feb 06, 2019Follower
WNA3100M - Does it support 5ghz, if so how do i switch to it?
- Gateway Version
Mint 17.2
I would like to know if I can use 5GHz with my WNA3100M, and if so, how do I use it?
I was on my gateway because I wanted to chan...
- Feb 06, 2019
Hi Niclas_sql
Welcome to NETGEAR Community!
WNA3100M is not a dual band adapter. It can only detect 2.4GHz WiFi network. To know more about this product, you may check this link WNA3100M Tech Specs
Blanca
Community Team
Blanca_O
Feb 06, 2019NETGEAR Employee Retired
Hi Niclas_sql
Blanca
Community Team
- michaelkenwardFeb 07, 2019Guru - Experienced User
There is a manual for the WNA3100M somewhere at the end of this link:
>>>> WNA3100M | Product | Support | NETGEAR <<<<
See the specifications there.
