SFD
Nov 17, 2010Novice
WNCE2001 inappropriately providing DHCP connections
I have a new WNCE2001 Wireless Ethernet bridge and have successfully configured it to connect my ethernet-only printer to my home network. This morning, I was unable to get to the internet from my iP...
fosor
Dec 16, 2010Aspirant
jmizoguchi wrote: This devce does not do dhcp
This is incorrect. The device DOES act as a DHCP server, and it appears to be a defect. When this happens, all the devices on my network, that obtain new leases, do so through the WNCE2001. This is verified in the IP information on each of the devices. In addition, the setup pages on the WNCE2001 device, specifically the Device Status page, under the LAN Port section, has the DHCP Server set to ON (where it is normally set to OFF). It appears that a reboot of the device turns it back off, but I cannot figure out what is turning it on. If anyone else is running into this - it's a real problem - call Netgear.
