SFD
Nov 17, 2010Novice
WNCE2001 inappropriately providing DHCP connections
I have a new WNCE2001 Wireless Ethernet bridge and have successfully configured it to connect my ethernet-only printer to my home network. This morning, I was unable to get to the internet from my iP...
jmizoguchi
Dec 16, 2010Virtuoso
still don't see it in manual
post screenshot
PG13 of manual
post screenshot
PG13 of manual
This screen shows whether the Internet adapter is set to get its IP address dynamically from
the router (this is the most common setting), or is set as a static IP address.
• Get Dynamically From Router: The wireless network router assigns an IP address
when the Internet adapter connects to its wireless network. Most networks are set up so
that the router automatically does this.
• Use Static IP Address: Specify a static IP address. This is not usually necessary. If you
set this up, you should be technically experienced or have a technically experienced
person help you.
- IP Address: The static IP address.
- IP Subnet Mask: The subnet mask associated with the IP address.
- Gateway IP Address:
- Primary DNS: The primary domain name server (DNS).
- Secondary DNS: The secondary domain name server (DNS).
