SFD
Nov 17, 2010Novice
WNCE2001 inappropriately providing DHCP connections
I have a new WNCE2001 Wireless Ethernet bridge and have successfully configured it to connect my ethernet-only printer to my home network. This morning, I was unable to get to the internet from my iP...
jmizoguchi
Jan 27, 2011Virtuoso
Here's my theory! If you look on the underside of the WNCE2001 there's a small platic shiny, rectangular cover that looks glued on. There is really small text below that read AP/CLIENT/RT. I bet that if I pop that little plastic peice off, there will be a tiny switch under there! And I would thing it should be set to CLIENT...but perhaps Netgear set it to AP (Access Point) by mistake. I'm a little afraid to attempt to pop off the plastic peice because I might void the warranty...but I'm getting to the point of wanting to crack it in half anywayz!
should be in client mode
