Regnjen
Jul 16, 2024Follower
WNCE2001.Old Model that won’t connect any more. Please suggest a newer model to replace old one.
I used the WNCE2001 adapter to connect my Yamaha Piano keyboard PSR S900 via LAN Cable. My PC has lost its connection and I cannot get it back to update the IP address and Password as the PC can’t fi...
Jul 16, 2024Guru - Experienced User
Why not just pickup a cheap extender with an ethernet port and connect that route?
The market for lan adapters isn't large.
- michaelkenwardJul 16, 2024Guru - Experienced User
If the keyboard does LAN and you can't connect directly to the router, an alternative is Powerline Ethernet. Turns the mains circuit into a fake LAN network. Not perfect, depends on the mains circuit, but adequate for stuff that doesn't move and easier to set up that anything that needs wifi. Can can also get powerline plugs that include their own wifi access point, to get wifi to other stuff near the piano.
