Bulldog009's avatar
Bulldog009
Follower
Oct 31, 2019
wnce2001 power led blinking red
G'day everyone,
I'm having trouble with my wifi adapter. I had it switched off for two weeks and now that I have plgged it in again i'm getting a blinking red led and can't reset it or connect with my router.
I would appreciate any help I can get, or recommendations for an equivalent wifi to ethernet adapter as a replacement. It needs ethernet connectivity to communicate with my APEX aquarium controller.
Thanks in adavance
John
1 Reply
  • plemans's avatar
    There's 3 led's on WNCE2001. Each one means something different. the lan port shouldn't be red though.
    if its the power led is blinking it means: unit is busy. try resetting it.
    If the power led is solid red it means its not getting enough power. try a different power adapter
    if the lan port is red it means your connection to the router is poor.
    So which led is it?
    have you tried a different power supply?
    have you tried a reset? push and hold the reset button until the power led blinks.
    here's the support site
    https://www.netgear.com/support/product/WNCE2001.aspx
    It is a bit of an older device. If its just for an aquarium you could replace it with a wifi extender that has ethernet capabilities. There's everything from cheap n300 extenders to expensive triband extenders.
