Vadim_
Aug 19, 2015Aspirant
WNDA 3100 v.3
The question is - has v.3 significant changes in hardware and firmware? I mean, for examle, if v.2 worked with TV Panasonic, do v.3 will work with it too?
JamesGL
Sep 28, 2015NETGEAR Employee Retired
Roberto72
Jan 08, 2016Aspirant
Is it possible to re program WNDA3100 V3 to V2 like serial number 2D4 as written below ?:
Note: You will need a WNDA3100v2 with serial number prefix of "2D4" to be compatible with the Panasonic TVs.
Thanks in advance
rs
- JamesGLJan 12, 2016NETGEAR Employee Retired
Hi Roberto72,
It is not possible to reprogram the V3 to V2. These are two different versions with different drivers.
- valterJun 17, 2016Aspirant
Hi Roberto I have de same problem. Have you solve it?
- JamesGLJun 21, 2016NETGEAR Employee Retired
Hi valter,
Only the v2 will work with Panasonic. The v3 will no support panasonic.
