Vadim_
Aug 19, 2015Aspirant
WNDA 3100 v.3
The question is - has v.3 significant changes in hardware and firmware? I mean, for examle, if v.2 worked with TV Panasonic, do v.3 will work with it too?
JamesGL
Aug 21, 2015NETGEAR Employee Retired
Hi Vadim_,
Welcome to Community!
These units are running on different driver versions. Not necessarily that if v.2 works with Panasonic then the v.3 should work as well. It depends on the software/driver if the said feature is available.
JamesGL
Community Team
Vadim_
Aug 22, 2015Aspirant
Hi!
Thank you!
Before I read your answer, I tried v.3 with Panasonic TX-PR42UT30. It doesn't work with this TV.
- JamesGLAug 25, 2015NETGEAR Employee Retired
I guess the reason for that is it might not be compatible with the Panasonic TV and only the version.
JamesGL
Community Team
