GerryPeters
May 03, 2019Aspirant
WNDA3100 v2 Can't find my network
I've used a WNA1100 on a XP computer for about a year and it tends to lose the network connection after a while and I have to reconnect it. I'm primarily using remote Desktop on the XP computer to c...
Blanca_O
May 05, 2019NETGEAR Employee Retired
Hi GerryPeters
Welcome to NETGEAR Community!
If the adapter detects the network then the adapter works fine. How do you connect to the network? Is it via NETGEAR Utility or Windows Utility? You can try to install the standalone driver.
Blanca
Community Team
- GerryPetersMay 05, 2019Aspirant
The adapter does detect the network. For some reason the password wasn't working to manually input it or by using the button to send to my modem
I think I was using the Netgear Genie to connect to the network? But it seemed a window did pop up that I think was the Windows Utility and that didn't work either.
The standalone driver was the first thing I installed and got nowhere with it, I thought may because I didn't first uninstall the WNA1100. But maybe I just didn't know how to use the standalone driver. I checked out the readme file and that didn't help.
What is the difference between the standalone driver and the Genie? How do I use the standalone driver correctly. Why would I use one instead of the other?
This post has given me hope that maybe I can solve this. I'll try somethings on Monday and get back to you. If you can enlighten me some with my questions above that may make Monday more fruitful
Thanks,
- GerryPetersMay 06, 2019AspirantI tried some things today. An XP window popped up with this:Wireless network connectionchoose a wireless networkmine does show up at topenter passwordlong wait - no window of the resultin list my network is at top and it says automatic with a gold star icon, showing full signal strength - but it's not connectedClick on Netgear icon in sys tray and open Geniemy network is not in the listchoose Push N connect option, press both buttonserror messageNetwork Genie - failed to join wireless network ATT2xxxxxit correctly lists my network nameYet in the Genie window it's not there even after Refreshselect different button in Genie - Home, Other, manually connect to a networknow it shows my networkchoose connect, a password screen pops up - hit ok, it don't connectnow my network is not showing in the Genie window even after RefreshWhat's the difference between Standalone and Genie?Any suggestions?
- GerryPetersMay 11, 2019Aspirant
Thank you Blanca for your initial reply. I replied to you with more info 5 days ago, would you please reply and let me know your thoughts. I'm still trying to see if this will work
Thanks
- Blanca_OMay 14, 2019NETGEAR Employee Retired
Hi GerryPeters
Please check this WNDA3100v2 Product FAQs
"What operating system patch or service pack do I need to install in my XP machine to ensure my wireless function works without an error?"
This could be the reason why the adapter is not working properly.
Blanca
Community Team- GerryPetersMay 14, 2019Aspirant
I have XP service pack 3 and all that's required is service pack 2. I did get WNA1100 to work, but it loses the network too often and I was hoping the WNDA3100 would work better.
Did you see my message 4? I filled in a lot of details few you in hopes this would give you more to work with. Please review it. What's the difference between Standalone and Genie?
Let me know what to try next
thanks,
