GerryPeters
May 03, 2019Aspirant
WNDA3100 v2 Can't find my network
I've used a WNA1100 on a XP computer for about a year and it tends to lose the network connection after a while and I have to reconnect it. I'm primarily using remote Desktop on the XP computer to c...
Blanca_O
May 05, 2019NETGEAR Employee Retired
Hi GerryPeters
Welcome to NETGEAR Community!
If the adapter detects the network then the adapter works fine. How do you connect to the network? Is it via NETGEAR Utility or Windows Utility? You can try to install the standalone driver.
Blanca
Community Team
GerryPeters
May 06, 2019Aspirant
I tried some things today. An XP window popped up with this:
Wireless network connection
choose a wireless network
mine does show up at top
enter password
long wait - no window of the result
in list my network is at top and it says automatic with a gold star icon, showing full signal strength - but it's not connected
Click on Netgear icon in sys tray and open Genie
my network is not in the list
choose Push N connect option, press both buttons
error message
Network Genie - failed to join wireless network ATT2xxxxx
it correctly lists my network name
Yet in the Genie window it's not there even after Refresh
select different button in Genie - Home, Other, manually connect to a network
now it shows my network
choose connect, a password screen pops up - hit ok, it don't connect
now my network is not showing in the Genie window even after Refresh
What's the difference between Standalone and Genie?
Any suggestions?
