EPR531
Mar 29, 2023Aspirant
WNDA3100v2 Netgear RangeMax
My WNDA3100v2 seems to have died after about 10 years - any suggestions for a suitable replacement product will be greatly appreciated!
Mar 29, 2023Guru - Experienced User
Jeepers thats an old router.
anything from the current generation of AX devices is going to be leaps and bounds faster than that device.
- EPR531Mar 29, 2023AspirantYa tell me about it! Any specific recommendations appreciated…
- michaelkenwardMar 29, 2023Guru - Experienced User
EPR531 wrote:
Ya tell me about it! Any specific recommendations appreciated…The choice is huge. It depends on what you want to achieve and how deep your pockets are.
Try plugging your needs into the filters on the product pages:
Wireless USB WiFi Adapters For PC & Laptop - WiFi 6 Adapters - NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
- plemansMar 29, 2023Guru - Experienced User
Like michaelkenward said, we'd need more info to give you a rough idea of what we'd recommend.
whats your budget?
What size home is it?
What speeds do you have there?
Do you plan on upgrading speeds?
How many devices do you need to support?
Is it for gaming/live streaming?
