n4hmrhamm
Jan 29, 2023Follower
WNDA4100 Genie program quit loading in Win 10
I am using the WNDA4100 adapter in Win 10, and it is working properly (as best I can tell). After the original install of the adapter and Genie, Genie would load fine but now it will not load. When...
Jan 29, 2023Guru - Experienced User
You don't need to use genie. Windows own built in wifi manager works fine.
Just uninstall the genie/driver/utility and install the stand alone driver. then let windows manage the adapter.
