bbentler
May 25, 2023Follower
WPA3-Enterprise support A8000/AXE3000 wifi 6E usb adapter
I am trying to test with the A8000/AXE3000 wifi 6E usb adapter running on a windows 11 machine and connecting to a 6Ghz AP/Router that supports WPA3-Enterprise with a Radius server. I attempt the con...
Bonzi916
May 13, 2024Aspirant
I spent hours trying to resolve this, not sure if you’re issue is the same, but what I eventually discovered is that the drivers for this product support windows 11 on ARM64, which is what I operate. They support Windows x86. Long story short there are some drivers that support ARM64, I haven’t done enough testing to find on that works yet, I know that Realtek has some, that’s where I’ll be starting.
Hope this helps. NETGEAR needs to get either times and upgrade their driver software.
