Janstrong
May 15, 2020Follower
1200 extender model ex5000
I can not connect the device, is there a phone number I can call
Burban123
May 22, 2020Aspirant
I checked for firmware update. Said no updates available. 1.0.1.64.
I did reset yesterday. Did not use WPS to setup this time. Instead after I reset. I chose the WIFIEXT settings then went in to configure. This is now working alot better. Don't understand why WPS didn't work that well.
Fingers crossed.
Brian
May 22, 2020Guru - Experienced User
wps is coded different between different device manufacturer's. so sometimes its best not to use if there's issues.
