C273
Mar 29, 2020Tutor
2.4 GHz Configuration Mismatch
After a wireless analysis I am getting an error - 2.4GHz Configuration Mismatch. Your access point in the 2.4 GHz Band are not all configured with the same HT Capabilities. We recommend configuring all access points in each band the same. The band are not all configured with the same PHY Types: EX8000 b/g/n/ac and R7900P b/g/n. How can I make the EX8000 b/g/n or the R7900P b/g/n/ac to make them match.
What's doing the wireless analysis?
do you have your EX8000 setup in extender mode or AP mode?
did you set it up via wps or the installation wizard?
What firmware is on the EX8000?
On the R7900P?
- C273Tutor
What's doing the wireless analysis? I am using inSSIDer
do you have your EX8000 setup in extender mode or AP mode? Extender Mode
did you set it up via wps or the installation wizard? Installation Wizard
What firmware is on the EX8000? V1.0.1.206
On the R7900P? V1.4.1.42_1.3.4 ( I was going to update to the latest one that came out a few days ago but people are reporting too many issues)
Yeah the version with armor hasn't been well recieved.
is the extender working?
is it just inssider reporting the issue?
do you have the 2.4ghz speed set for 450mbps and airtime fairness enabled?
