xdamageincx
Apr 14, 2021Aspirant
2 Electric systems Wifi Range Help
v1.4.1.68 I have a tall home that the router is being moved to a central location (now on the 6th floor). The garage is 150' away from the house (and 50' long away from router location).on a seper...
xdamageincx
Apr 17, 2021Aspirant
Does anyone know if this is compatible with the Nighthawk 8000? Does it go on the far end of the range, in between (I have outdoor power halfway to the garage) or does it go on the outside of the house facing toward the garage?
Netgear RBS50Y AC3000 Orbi Outdoor Tri-Band Wi-Fi Range Extender for Wi-Fi Routers
