Redjasper30
Nov 29, 2023Initiate
2 Extenders and 1 router setup
Hi, trying to setup WiFi in my home garden office. I have x2 EX7000 extenders to work with my BT homehub 2 router. My idea is to connect the first extender to the Homehub router via WiFi and then use ...
Nov 30, 2023Guru - Experienced User
yes you could.
You'll setup the wireless one first with it in extender mode.
Then during the setup of the 2nd, because its hardwired in, it needs to be setup in access point mode.
That tells it to use the hardwired connection for the connection back to the router.
Should work fine.
Redjasper30
Nov 30, 2023Initiate
I’ll give it a go, thanks
- plemansNov 30, 2023Guru - Experienced User
Hope it works well for you!
