RNL605's avatar
RNL605
Follower
Apr 20, 2020
2 Netgear Powerlines config for one Network? (PLP2000 - 2000mbps & PLW1010-100NAS - 1000mbps Wifi
I have two Netgear Powerline systems...  PLP2000 (pasthrough) and PLW1010 (passthrough with wifi)
I'm trying to find a way to set the system up where I have ONE unit at the router, and 3 through out the house.   My guess is I would use the PLW1010 at the router since my Internet provider is has a max of 1000mbps...  I would then have the other 2 powerline 2000 units at two locations connected directly to devices, and the PW1000 Wifi device in a deadspot in my home.
I can't seem to get that set up to work... it is either the 2000, or the 1000,.not both.
Is there some sort of configuration I can do?   or is this just not possible?
I'm not a techy... so simple instructions please
No RepliesBe the first to reply
