ColinWB's avatar
ColinWB
2 pc's both only work with cables, wifi not working
I have had a wifi router made by another company for some time but then I got the dreaded "No Internet Connection" message on my #1 machine and as I couldn't immediately sort it, I fired up my second laptop and that too was unable to make a connection. I then used a cable direct from my Wimax modem and everything is fine on BOTH laptops. Ahah ! We said. The router has failed; no apparent reason but perhaps it's the transformer, after all we've got the builders in and the power is going off and on all the time..... every other piece of equipment works perfectly though. So, I bought a new Netgear router and that should be all right. But it isn't. I still have the issue on both routers on both laptops - they work with cables but not with wifi. Anybody got any ideas? A virus somewhere? Well my Avast is paid for and is current and says there are no problems. The Wimax carries not only the Internet connection but also my telephone which works perfectly and the local forum is not posting any problems.
  • Retired_Member's avatar
    Retired_Member
    Have you tried connecting to either router via cat 5 cable to verify weather or not you have a connection. New router usually requires a modem reboot to acquire IP from modem/ISP.
  • Yup, Cat 5 ethernet cable.....both from the wifi modem and from the Wimax modem. I think I've tried all permutations before making the initial request for help.
    Retired_Member
    Contact support! Yup I would contact support.
  • Just found out it's the new 2.3gH cordless speakers conflicting with the router.
