mleone22
Oct 12, 2020Aspirant
2 Range Extenders
I purchased a 2nd WiFi Mesh Range Extender EX6250 because the 1st one worked so well. Very impressed. We placed one on first floor which gave us better wifi coverage upstairs too. And I purched a 2nd...
Oct 12, 2020Guru - Experienced User
Are they both connected and working?
If you log in through the browser do they both show?
Reason I ask is the app isn't always accurate
mleone22
Login to Netgear.com? I'm looking. I don't see a link in the menu to "My Devices" etc?
- mleone22Oct 12, 2020Aspirant
I see it now under MyNetgear, but I only see 1 device. I have 3 green lights on my new 2nd extender. But there are 4 green lights on my 1st device. Not sure what I'm missing.
- plemansOct 12, 2020Guru - Experienced User
which 3 lights are green?
I just mean log into your router through the browser. Not sure what router you have but it should have an online portal to change its settings.
Yes, I only see one extender in my connected devices on my router. This 2nd one doesn't seem to be connected in my router. 3 solid green lights including the Router Link LED, but the light to the right is not on.
