GS972's avatar
GS972
2 routers on different networks setup
MK63 — Nighthawk Mesh WiFi 6 System I have a complicated setup question for the Nighthawk Mesh MK63. I want to set up the Mesh in the following way. IP addresses for example: 76.76.76.76 10.10.1.1 ...
  • GS972's avatar
    Sep 21, 2020
    I'll answer my own question. After some trial and error I found it is not possible because the AirPort Extreme is not configurable enough. When you connect to the extreme it will only work in bridge mode.  To get around this I connected a dynex 401 router to the Netgear lan port and setup the second network.  Then put the 2 extremes in bridge mode and created the separate wireless network and guest network.
