GInnes
Jan 13, 2020Aspirant
2 Routers
I just purchased the R8000 and hard wired it to my Specttrum modem. This is set in my basement where the wires come into the house. I then have a 2nd Belkin 5G Modem connected to the Nighthawk by...
Jan 14, 2020Guru - Experienced User
1. What spectrum modem is it?
2. You put R8000 in the post and ex8000 in your signature. is it the R8000?
3. What belkin is it? is it running in access point mode or router mode?
If you're running 2 routers in router mode, you're probably in a double nat which can cause issues.
GInnes
Jan 14, 2020Aspirant
The spectrum Modem is an Arris Model TM1602A The 2nd Router is a Belkin N600 DB Wireless N+ Mmodel F9K1102V2. I have no idea which mode it is in but I assume Router since that was what I was using before the Nighthawk. I have no idea how to check or change if necessary. I looked at the link you gave me and see that if I can figure out how to modify the Belkin it is suggesting that I put the belkin in the basement then the Nighthawk at the end of the chain in my office on the third floor. My question then becomes:
1) will I loose signal going from the Belkin and traveling a 100 feet by ethernet cable to the office. Isn't better to to have the stronger Nighthawk closer to the modem? 2) Can the Bridge be at the end of the chain? In my office I only have my computer and printer connected currently to the the Belkin? 3) In Bridge mode can Router recieve or am I essentially no longer able to connect to it except by ethernet cable?
- plemansJan 14, 2020Guru - Experienced User
Here's what I'd do:
Modem------>netgear (better base router)------->belkin.
The netgear is the better router so have it after the modem in router mode. put the belkin in access point mode.
100ft is a fine distance. cat5e can run up to 300ft.
You can still have the printer and computer connected to the belkin in access point mode. Access point just shuts off the dhcp server of the router and makes all the devices on one subnet.
- GInnesJan 14, 2020Aspirant
Thats great and what I was thinking about the order. Now how do I tuen the Belkin into just an acess point
. Any suggestions on wha hardwatre I would need add a wireless reciever that I could run an ethernet cable to a Tv that is not wireless and requires an ethernet access for smart features? It doesn't have wireless and running a line is a problem Thanks
You could try a powerline adapter. They work pretty good for situations like that.
