dilloninmn
May 05, 2022Tutor
2 WiFI extenders Login
If I setup 2 extenders is the house how do I login into them? It would appear that the same url is used for all wifi extenders.
- May 06, 2022
You can use the ip address from them. Log into your router and find the ip address for each.
You'll be able to use that to log into them.
Fyi, I highly recommend when using more than 1 extender to not daisy chain them.
Daisy chain: router---->extender----->extender
Set them up in star configuration for best results:
Star: extender<--------router-------->extender
May 06, 2022Guru - Experienced User
Should it? yes.
Does the app always work as it should? more doubtful.
Usually when people are needing more than 1 extender, we recommend moving to a mesh system both because of performance and ease of use. When using more than 1, many times you need to use its ip address to log directly into the one you want.
dilloninmn
May 06, 2022Tutor
Thanks for the help much easier than calling tech support 🙂
