georgep54
Jun 26, 2012Aspirant
~2MB/sec performance OK for WG103?
Hello- I have 3 prosafe WG103 switches, and the FTP file transfer rate I get when copying a file between two connected nodes in the network, is 2MB Is this acceptable or should I be seeing bette...
fordem
Jun 26, 2012Mentor
As you have discovered WiFi is not the greatest medium for bulk data transfers, and a lot will depend on the environment...
First - you're using 802.11g so you are limited to a theoretical maximum of 54 mbps, which translates to somewhere in the region of 20~30 mbps throughput - or 2~3 MB/sec - and yes, I do know it's 8 bits to a byte, your data transfer will also include addressing, check sums, etc, so there is some "overhead" that needs to be accounted for.
Next - Wifi is half duplex - the radios can not transmit & receive at the same time, and there is a certain degree of "switching latency", which causes a further degradation of potential throughput.
Last - transferring data between two WiFi nodes associated with the same access point (whch may or may not be the case in your particular scenario) requires special consideration - the sequence of events goes like this ...
- Node A transmits to the access point
- Access point switches RX/TX modes.
- Access points transmits to Node B.
The above sequence ignores (for simplicity) the acknowldegements and so on required by the protocols, which would actually further reduce throughput, but from it, you can see that the 2~3MB/sec projected throughput is actually reduced to under 50% - and this is not even a worst case scenario - it's a "single access point scenario"
Best case scenario - your WiFi nodes are associated with different access points in which case the 50% degradation MAY be eliminated, depending on what's actually happening with the other network traffic.
Worst case scenario - you have interference between your multiple access points and CA (collision avoidance) kicks in, further degrading throughput.
I'd say your 1.86 MB/sec is not bad, it could be better, but it could also be worse.
