georgep54
Jun 26, 2012Aspirant
~2MB/sec performance OK for WG103?
Hello- I have 3 prosafe WG103 switches, and the FTP file transfer rate I get when copying a file between two connected nodes in the network, is 2MB Is this acceptable or should I be seeing bette...
fordem
Jul 10, 2012Mentor
First - I'm not familiar with the iPad, however on Windows systems there is a setting for what can be described as "roaming aggression" this is what determines how aggressively the device will search for stronger signals.
Second - if you are using different SSIDs the iPad (or any other wireless device) will consider your access points to be different wireless networks and will not roam, but will do their best to stay connected to the chosen network.
