brsemple
Sep 04, 2015Follower
3 + huwei e385 + WCDMA repeater reception poor. wifi extender which netgear would you use
I live in ireland and get my broadand from 3 via a huwei e385 and a WCDMA repeater but reception is still poor. Would I benefit from using a wifi extender and which would you recommend from netgear r...
nhann
Sep 04, 2015NETGEAR Employee Retired
Hi brsemple,
If you are experiencing wireless obstruction in different rooms, you might also consider NETGEAR powerlines: http://www.netgear.ie/home/products/networking/powerline/
WiFi Range Extenders: http://www.netgear.ie/home/products/networking/wifi-range-extenders/
Please see the above links and run a comparison to see which product fits your requirements.
