bili
Apr 09, 2022Follower
3 years old EX2700 setup
I have a 3 years old EX2700 extender. I replaced my router and now unable to setup my extender. How can i connect it to my new router without WPS. I still have my login access to www.netgear.com.
Apr 10, 2022Guru - Experienced User
You can set it up using the installation assistant.
Factory resets it (push and hold reset for 7-15 seconds while powered on) and then install it using the assistant.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
