PatrickCameron
Aug 01, 2020Aspirant
5G band on Netgear ex6150 not working with PS4
My PS4 won't connect to this device (Netgear Ex6150v2) on the 5G band, I'm a computer tech, I checked all the channels, my phone and laptop connects to it to it, but not the PS4. I used a wifi analy...
Aug 01, 2020Guru - Experienced User
Which model ps4 do you have? Not all models were dual band.
PatrickCameron
I got both ps4 and ps4 pro... IDK... on my pro I can see the SSID, but can't connect... even if I hold a wifi analyzer (on phone) in the same spot and test for the DB.... 1meter through a wall, can't connect...
- plemansAug 01, 2020Guru - Experienced User
Does it connect to the primary routers 5ghz?
How did you setup the extender? using wps or using the installation wizard?
- PatrickCameronAug 01, 2020Aspirant
Yes, connects direct to router 5G. I used installation wizard for extender...
Also, I have two of these extenders, the other one not opened.. can test if same problem with another extender... but I saw someone else had same issue with same model:
https://gamefaqs.gamespot.com/boards/691087-playstation-4/75550789
... Thinking about returning the other one if not both... idk...
But for the price.. I hope I can get it to work or Netgear does firmware update to fix issue...
which version of firmare are you on?
are you running it with mesh mode? (same ssid function)
Any special characters/spaces in the ssid and password?
