Blue24
Jan 26, 2020Aspirant
5g WiFi nolonger able to connect to internet through 3700 extender.
My dad recently switched our WiFi provider to Frontier, the router has dual band WiFi, It provides 2g and 5g bands. We have a range extender upstairs that we used with the previous wifi, I connected i...
Blue24
All the LED lights are green except for the router light, it's blinking orange and green. The router is an Arris NVG468MQ, provided by Frontier Communications.
Jan 26, 2020Guru - Experienced User
did you try logging into the extender to check signal strengths?
The led doesn't show both 2.4ghz and 5ghz. 2.4ghz broadcasts further and through more materials but has much slower throughput than 5ghz. Try loggin in and checking. Also try moving the extender closer. Maybe the router isn't as good and the extender needs to be closer.
