Marz24
Jan 21, 2019Aspirant
5Ghz connection failed! EX6110 WIFI RANGE EXTENDER AC1200
First of all, my name is Marz and hello to the community.
I have this brand new netgear wifi extender that support both 2.4ghz and 5ghz connections. For some reason I can't establish a connection bet...
Christian_R
Jan 25, 2019NETGEAR Employee Retired
Hello Marz24,
We recommend contacting support to utilize your 90 days of support: https://www.netgear.com/support/default.aspx
~Christian
BakerChris
Jun 02, 2019Aspirant
Hi There, I have the exact same problem and was wondering if there was a solution provided by Netgear, if not I will return the product. Any information would be greatly appreciated.
Christopher Baker
Christopher Baker
- Marz24Jun 02, 2019AspirantReturn your product mate. There is no solution for this problem. This product is simply doesn't do what it says in the box. I regret buying it.
