Marz24
Jan 21, 2019Aspirant
5Ghz connection failed! EX6110 WIFI RANGE EXTENDER AC1200
First of all, my name is Marz and hello to the community.
I have this brand new netgear wifi extender that support both 2.4ghz and 5ghz connections. For some reason I can't establish a connection bet...
BakerChris
Jun 02, 2019Aspirant
Hi There, I have the exact same problem and was wondering if there was a solution provided by Netgear, if not I will return the product. Any information would be greatly appreciated.
Christopher Baker
Christopher Baker
Marz24
Return your product mate. There is no solution for this problem. This product is simply doesn't do what it says in the box. I regret buying it.
