Guyg
Mar 09, 2021Follower
6400 ext not showing up as a WiFi network for setup
Trying to install WiFi extender following the instructions but it doesn’t show up as a network choice
MrGilmore
Mar 20, 2021Aspirant
Can't get it to come up on any devices. It says it's connected to our wifi though
- plemansMar 20, 2021Guru - Experienced User
Did you set it up using wps?
Or using the "onessid" function?
If so, it won't show up as a seperate network because its a mesh device. It uses the same ssid as the router and standard scans see them as one network.
