cnaray
Sep 06, 2019Aspirant
7300 FastLane setup
Please explain Fastlane. I want both 2.4 and 5.0 connections from the extender but I could live with a 5.0 only if it will help my range. I have a gig transfer rate from my router. The two options...
cnaray
Sep 07, 2019Aspirant
Thank you for your reply but I still am confussed about which FastLane option to pick if I want the best 5Ghz out put connection to the device I'm using. Thank you again.
Sep 07, 2019Guru - Experienced User
More info on fastlane.
https://kb.netgear.com/24662/What-is-FastLane-Technology-and-how-do-I-configure-it
I can't tell you which one is going to work the best because everyones house/situation/wifi interference is different. Its easy to change them back and forth so you can easily test which one works best for your environment.
