GstaatsG
Sep 20, 2022Follower
900 wifi range extender ex7000
Trying for two days now to link with my Spectrum router (so-cal) Sends me in a loop, doesn't give clear instructions, can anyone tell me why???
1 Reply
Not sure what the 900 is about.
What actual model router are you connecting it to?
What method of setup are you using the the EX7000? The push button wps, the installation assistant, the app?
And what error is it giving you?
You put its sending you in a loop but that doesn't tell us much about whats going on, what error you're getting, or even what its doing.
Details are key in helping out.
