Ozmannn987
May 21, 2020Follower
A6150 USB ADAPTER
Hi, I bought a A6150 Dual Band WIFI USB Mini Adapter, i wanted to use the product for my xbox one, i was wondering if anyone cou;d tell me how i can use the product for the xbox one? I did s...
May 21, 2020Guru - Experienced User
The A6150 is compatible with windows and mac.
Xbox one doesn't run windows or mac.
That's probably why they provided you with little information.
You need to buy a xbox one compatible wireless adapter.
