ohjeans
Aug 28, 2019Aspirant
AC 1200 DUAL BAND WIFI RANGE EXTENDER EX6120
I just signed on for Spectrum internet service, and now have TM1602 Arris modem and a Spectrum router connected to it via a yellow ethernet cable. I have one dead zone in the house, so I just bought...
ohjeans
Sep 07, 2019Aspirant
Thank you for the reply. I have tried resetting as you suggested, watching for the light to change. That did not work for me. I am trying to set it up and connect wirelessly. Also I tried to connect using the online method, but the web page told me it could not find my extender. Perhaps I was not using the web page correctly. I thought I was following the directions line for line, but no luck. Finally, can you give me an explanation for how to connect to the wireless modem using a cable? Maybe that will work. Thank you.
Sep 07, 2019Guru - Experienced User
I just mean connect a computer to the extender via the ethernet port for setup. Tends to go a little smoother.
