EliRolling
Sep 25, 2018Initiate
AC 1900 WiFi Range Extender EX7000
Recently, the extender has been acting strange with the connection going in and out. This occurred after the router (Nighthawk) being updated. A new firmware update has come out for the EX7000 but eve...
- Sep 26, 2018
Eli,
You're not the only one, I'm having the same issue here =/.
1) Edit: Follow this link:
https://kb.netgear.com/000060211/EX7000-Firmware-Version-1-0-1-78
2) Scroll down the page until you see:
"Download Link: http://www.downloads.netgear.com/files/GDC/EX7000/EX7000-V1.0.1.78_1.0.140.zip "
3) Save the file and unzip it (you will be uploading the file with the .chk extension). Once that is complete, log into mywifiext.net and go to firmware upgrade. Go to your downloads folder and find the unzipped folder. On mywifiext, navigate to firmware upgrade, select browse, then click on the .chk file and upload it. It'll take a minute or two, but it worked for me =]!
Hope this helps!
Edit (again): This is a direct link to the new firmware.
Red_Jester
Sep 26, 2018Tutor
Eli,
Hope this helps!
EliRolling
Sep 26, 2018Initiate
Thanks alot! The update worked but for whatever reason my extender still drops connection and then it comes back( the green Ghz and arrows lights will turn off and come back on). This was a problem before the update just to clarify.
