EliRolling
Sep 25, 2018Initiate
AC 1900 WiFi Range Extender EX7000
Recently, the extender has been acting strange with the connection going in and out. This occurred after the router (Nighthawk) being updated. A new firmware update has come out for the EX7000 but eve...
- Sep 26, 2018
Eli,
You're not the only one, I'm having the same issue here =/.
1) Edit: Follow this link:
https://kb.netgear.com/000060211/EX7000-Firmware-Version-1-0-1-78
2) Scroll down the page until you see:
"Download Link: http://www.downloads.netgear.com/files/GDC/EX7000/EX7000-V1.0.1.78_1.0.140.zip "
3) Save the file and unzip it (you will be uploading the file with the .chk extension). Once that is complete, log into mywifiext.net and go to firmware upgrade. Go to your downloads folder and find the unzipped folder. On mywifiext, navigate to firmware upgrade, select browse, then click on the .chk file and upload it. It'll take a minute or two, but it worked for me =]!
Hope this helps!
Edit (again): This is a direct link to the new firmware.
Henk999
Oct 14, 2018Initiate
I have also problems with losing connection after upgrade to firmware 1.0.1.78_1.0.140 mainly the 5 GHz connection
I'm using the Fast Lane mode.
Even resetting to factory defaults will not work, still losing connection and also trouble with configuring the fast lane mode => 5 GHz not working.
I reloaded the older version V1.0.0.66_1.0.126 and configured the Fast Lane mode again and everything works fine again.
I hope the next firmware upgrade will be a stable version
