RobertDHall3
Dec 16, 2018Aspirant
AC 1900 WiFi Range Extender EX7000
I am having trouble connecting devices to the Range Extender Wifi ID unless I manually enter an IP address for each device, It won't automatically assign one, and I cannot connect devices like Nest C...
Dec 17, 2018Guru - Experienced User
What firmware are you running?
RobertDHall3
Dec 17, 2018Aspirant
Don't know - the latest because i did a firmware update and it said it was up to date
- StephenBDec 18, 2018Guru - Experienced User
Try resetting the extender, and downgrading the firmware to 1.0.0.66 ( https://kb.netgear.com/000059563/EX7000-Firmware-Version-1-0-0-66 )
- pkincyDec 18, 2018Aspirant
I will try your suggestion. The new firmware has completely bricked my AC1900EX7000 like it has many others.
Unfortunately right now I can not connect to either of the ext bands. So Mywifeext.net does not recognize the EX7000. Any suggestions how I can roll back the firmware would be appreciated.
I did downgrade to firmware 66 and it worked for a few minutes but quickly quit working. After spending 7 hours on this problem and trying to get the AC1900 EX7000 to work, I am giving up. It has given me a couple of years of good service and it is time to buy the updated model and hope it works for a couple of years.
