abberow
Aug 28, 2020Aspirant
AC 750/EX3700 WiFi Range Extender will not reliably connect to router after update to 1.0.0.84
I got an email to update to a newer version of the firmware. There were many problems after the update starting with I had to ping mywifiext[dot]net to get the IP address as putting it into the URL w...
abberow
Sep 28, 2020Aspirant
I experienced the same issues, including the need to use the extender's IP address, but could not get even a short-term connection. I could not get a ticket; I presume because the unit is out of warranty. I tried a reset and used an ethernet cable without wi-fi. The reset did not reset the firmware - V1.0.0.84_1.0.56
I will keep an eye on this thread. If you remember and have the time, please post the results.
Thanks
Alan
Tahlan
Jan 31, 2021Aspirant
Same issue, after Firmware Version 1.0.0.84, I just keep seeing frequent disconnects/ reconnects from my on the logs of my main router. Looking for advice.
