Jul 27, 2020Guru - Experienced User
The EX6100v2 is a mesh extender. Meaning if you set it up using mesh or using the WPS setup method, it'll use the same ssid as the router.
Did you set it up using wps?
You can hardwire into it and follow the installation guide instead of wps
Fran_123
Jul 27, 2020Aspirant
Thank you
My router doesn’t support VSP so I used the nighthawk App
