Janemclaren
May 22, 2022Aspirant
Ac1200 connection issues
I’ve had an ac1200 running for an extended period with no issues, set up using manual settings rather than wps. After connection issues over a period of time I’ve ended up with a full reset of the mo...
shakirfateh
Network adapter Speed and Duplex setting.
Check the wires.
Router settings: Your router should support Gigabit speeds, also check that you have the latest firmware installed, enough cooling is provided, and QoS should be disabled.
best regards
