SandraStark
Sep 04, 2021Aspirant
AC1200 Dual Band Range extender
The extender is clearly linked to my computer and its address shows up in the list of networks on my iPad. But when I click on the address on my iPad, it asks for a password. I have no idea what the ...
Sep 04, 2021Guru - Experienced User
Did you setup the extender using wps? if so, use the password for your routers wifi
If you set it up using the installation assistant, you'd have either setup your own or used the routers password.
- SandraStarkSep 04, 2021Aspirant
Yes, but what is the router's password.
- plemansSep 05, 2021Guru - Experienced User
That'd be something you know, not us.
If it was that easy to guess someones passwords, hackers would have it easy.
If you changed your routers password, thats what it'd be.
If you left it default, look on your router to see if its on a label anywhere.
